please help with 10 bolt disc swap! !!
Old Mar 26, 2012 | 04:57 PM
srcopley350's Avatar
Car: 1985 Camaro Z-28
Engine: GMPP 350/290
Transmission: Soon to be 700r4
I have the factory 10 bolt drum brakes rear end in my car now I've recently acquired a 1990 model 10 bolt rear end with the disc brakes out of an IROC. My car is an 85 model. Has anyone done a well documented swap? If not what all will this entail (parts, prices, link to information and photos) . I have searched but haven't found what I am looking for.
Old Mar 26, 2012 | 05:46 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: please help with 10 bolt disc swap! !!
Welcome to TGO.
Direct swap. You'll need the first-design 1LE combination valve, first-design parking brake cables and the correct drive and/or driven gears if the rear ratio is different than the original. Check the the 10-Bolt FAQ sticky for more info.
JamesC
Old Mar 27, 2012 | 07:20 AM
These " first design" parts come off of which year and model. Are there aftermarket companies making them and what about brake lines?
Old Mar 27, 2012 | 07:29 AM
JamesC's Avatar
The first-design 1LE valve, which fits metric valves up to mid-89, can be purchased from the following company:
http://www.flynbye.com/
Various other part numbers, including the first-design parking brake cables, can be found below:
https://www.thirdgen.org/forums/faq-...iscs-89-a.html
Unless you wish to buy new, hard lines aren't an issue (though a part number is provided above, IIRC).
JamesC
hectre13
Dec 11, 2023 08:14 AM
sailtexas186548
Jan 19, 2016 12:21 PM
gta90
Sep 15, 2015 04:00 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
