700R4 Shifting woes
Old Apr 3, 2012 | 04:08 PM
89newfun's Avatar
Car: 1989 Camaro
Engine: Sbc 355
Transmission: TH350
Axle/Gears: 3.42 Detroit locker
700R4 Shifting woes
New Question:
When I originally removed the trans from donor car I lowered the trans and didnt unhook the tv cable with the trans, I did unbolt the housing but didnt unhook it. Could I have stretched something or bent something within the trans?
*Issue*Quick 1-2 Shifts at WOT and Bad downshifting when WOT passing.
I have searched through the past 700r4 Threads and have come up with a couple solutions.. Here is my problem. I have a 1991 700r4 at WOT the shifts from 1-2 seem to be way early. At a stop I can mat it to the floor and it shifts before it feels like I get moving. Also having an issue with WOT downshifts at cruising speed, as in I stomp on it and it doesn't downshift properly. Acts like it goes from 4-3 with no passing ability.
Already: Adjusted the TV cable, checked the governor..
Solutions found?: Governor gear recalibrate, corvette servo..
Cons: The motor and trans is now in a 1989 camaro. I swapped all the engine harness and wiring, But I did not change the dash wiring. Also speedo on trans is elec and car body is mech
What could be causing the quick shifts and the ******* downshift at passing WOT.
Could the electric speedo on the trans not be getting a proper read since it doesnt connect to the cars actual speedo?
Old Apr 3, 2012 | 04:43 PM
Coyote850's Avatar
Car: '83 Z-28
Engine: 5.0 CFI
Transmission: 700-R4
Re: 700R4 Shifting woes
I am by far not an expert, but it sounds like the car is not communicating proper engine RPMs to the transmission.
Old Apr 4, 2012 | 09:18 AM
89newfun's Avatar
Car: 1989 Camaro
Engine: Sbc 355
Transmission: TH350
Thats similar to what I was thinking. But its not an electric trans, I thought that the 700r4 was just controlled by fluid pressure.. I dunno Im hoping to find a fix through some expert help on here..
Old Apr 4, 2012 | 12:08 PM
89newfun's Avatar
Car: 1989 Camaro
Engine: Sbc 355
Transmission: TH350
Help Needed
*Bump*
Old Apr 15, 2012 | 04:43 PM
Joe_the_squid's Avatar
Car: 1990 IROC-Z
I'm actually having a similar issue. I swapped from 305 to 350 but haven't got my chip yet. I expected it to run rich but not the tranny issues. I did notice some silinoids on it that seemed cracked/broke when i disconnected them and dropped my tranny for install. I also thought the 700r4 we non electronic.
Old Apr 26, 2012 | 09:57 PM
88Trans-am's Avatar
Car: 88 GTA Trans-am
Engine: 350 vortec TPI(in process)
Axle/Gears: 3.27 LSD
sounds like my issue, did the 305 to 350 swap and after I put in a b and m shift improver kit..my trans won't downhill at all at WOT... All it does it hesitate and backfire....and yes I have my tv cable set right.....if you figure it out please post how
Old May 13, 2012 | 07:11 AM
89newfun's Avatar
Car: 1989 Camaro
Engine: Sbc 355
Transmission: TH350
The 700r4 isnt electric, it uses pressure to do all the work, only thing electric i believe is the converter lockup. Im still having the same problem, think Im going to break down and go to trans shop.
Old May 13, 2012 | 11:49 AM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
I would change the govenor springs
Old May 13, 2012 | 01:07 PM
89newfun's Avatar
Car: 1989 Camaro
Engine: Sbc 355
Transmission: TH350
actually put in a corvette gov to start and it is the same with the shifting issue..
question: When I originally removed the trans from donor car I lowered the trans and didnt unhook the tv cable with the trans, I did unbolt the housing but didnt unhook it. Could I have stretched something or bent something within the trans?
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
indygene
Sep 26, 2015 11:21 AM
6998poncho
Sep 25, 2015 02:56 PM
