Th350 speedo question
Old Apr 6, 2012 | 03:11 AM
92WS6 T/A's Avatar
Car: 1992 WS6 T/A
Engine: Turbo 383 with Holley Sniper
Transmission: factory 5 speed now Powerglide
Axle/Gears: Strange 12 bolt w/373 locker
I've got a 92 T/A 305tpi 5 speed. Im puttin a MUCH stronger motor in it so im doin a th350 swap. Now my question is, how do I make my electric speedo work with this swap?
Old Apr 6, 2012 | 04:02 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: Th350 speedo question
Make sure the TH350 has a Chevy tailhousing with 1" speedo gear hole.
Use a crossmember that mounts the front end of the torque arm off the transmission.
Swap your speedo gears over to the TH350.
Done.
Old Apr 6, 2012 | 07:41 AM
92WS6 T/A's Avatar
Car: 1992 WS6 T/A
Done.
Ok I understand the tailshaft part but the torque arm part is a little hazy. Doesn't it mount to the tailshaft?
Old Apr 6, 2012 | 09:14 PM
krisner89's Avatar
Car: 87 camaro
Transmission: th350
Axle/Gears: auburn 4.10
you have to buy a b&m adapter that bolts to the th350 tailshaft and has a bracket for the torque arm. If your new engine is around 500+ hp I would not go that route because i dont think the adapter is made to hold that much power.
Another option is to buy a kit that eliminates mounting it to the trans. It comes with a new torque arm and a bracket/crossmember that mounts it to the front subframe. Costs alot more but is alot stronger.
Old Apr 6, 2012 | 09:26 PM
krisner89's Avatar
Car: 87 camaro
Transmission: th350
to my knowledge there is no th350 with a elec. speedo. so youll have to get a adapter that converts a mechanical speedo trans to elec speedo gauge. Its been awhile since i looked at them last but i kinda remember them being priced high.
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
If your still using the sd ecm as a buffer 1227730 use this
http://www.tpiparts.net/inc/sdetail/7587
Old Apr 6, 2012 | 09:27 PM
Engine: Lb9
Transmission: M20
Old Apr 7, 2012 | 10:19 AM
92WS6 T/A's Avatar
Car: 1992 WS6 T/A
My trans already has a tailshaft with the torque arm mount. I think it will be ok. But if not ill look into the sub frame mount. Thanks for the info.
Eric2ndGen
Nov 5, 2015 01:51 PM
stickychinsac
Aug 31, 2015 06:06 AM
IROCZDAVE (88-L98)
Aug 24, 2015 06:54 AM
redmaroz
Aug 16, 2015 11:40 PM
Irocohio
Aug 12, 2015 08:03 AM
