Bad tv cable?
Old Apr 8, 2012 | 07:54 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
Bad tv cable?
How can you tell if you have a bad tv cable? When ever I drive my car for around 30 minutes or so my tv cable either sticks or comes out of adjustment because after I drive it my shifts are harder and it doesn't shift till higher rpms, after it starts doing this I can come home and readjust my cable and it will shift fine, any ideas?
Old Apr 8, 2012 | 09:49 PM
Engine: L31 350
Re: Bad tv cable?
bumb before the night
Old Apr 8, 2012 | 10:15 PM
91 1LE's Avatar
Car: '91 1LE
Engine: 377 w/Stealthram
Axle/Gears: 3.42 Torsen
Re: Bad tv cable?
Have you checked the fluid level? Sounds like it may be low. A far as the cable goes, they don't really go bad unless the adjuster mechanism can't hold it's position. Is the button fully seated after adjustment?
Old Apr 9, 2012 | 05:55 AM
Engine: L31 350
Re: Bad tv cable?
Fluid levels fine and I guess the button stays seated, it's like this till I go out for a long drive
Old Apr 9, 2012 | 10:09 PM
Engine: L31 350
Re: Bad tv cable?
Bumb for te night
Old Apr 9, 2012 | 11:16 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: Bad tv cable?
spelling bump correctly might net you some replies.
Old Apr 10, 2012 | 06:09 AM
Engine: L31 350
Re: Bad tv cable?
Its my phones autocorrect thank you
MM2Robinson
Oct 1, 2017 09:16 AM
DiabloWS6
Southern California Area
Feb 15, 2016 02:08 AM
TheTraut88
Sep 11, 2015 05:16 AM
TheTraut88
Sep 7, 2015 05:22 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
