can I get a little more out of my 700r?
Old Apr 14, 2012 | 04:48 PM
RachaelRider16's Avatar
Car: 1989 Camaro RS
Engine: 5.0 ltr. 305 TBI stock with holes d
Transmission: T-5 five speed
What's up everyone? I've got a '92 T/A WS6 with a 305 that has been bored .030 over. Nothing too big, but I was wondering if the B&M Saturday night special torque converter would be okay to use. Will it change the shift points and the lock up? Also is there any way to boost the line pressure, maybe get a crisper shift?
Old Apr 15, 2012 | 03:54 AM
Pro Built Automatics's Avatar
Re: can I get a little more out of my 700r?
B&M torque converters are junk. There are good torque converters that are inexpensive. The 12" Edge can be made to have apx. 2,500 rpm stall with your 305ci. They come with a 2 year warranty and cost $325.00. If you have more money to spend, then go with the Edge 9.5" lockup torque converter. The 9.5" TC will give you a little more performance than the 12", but it depends on what you are trying to do here. Add the Corvette servo, and the larger boost valves at a minimum for better shifts and a longer transmission life. A good Shift kit would be the way to go if you want to do the most to it, but the above modifications should do ok to start with.
Old Apr 15, 2012 | 06:54 PM
Car: 1989 Camaro RS
What's the website for that?
Old Apr 15, 2012 | 11:57 PM
Go to www.700r4l60e.com Call me with any questions.
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
Ratchet
Dec 7, 2001 09:34 AM
tiffosi
Feb 19, 2001 01:28 AM
Metallica383
Oct 1, 2000 10:24 PM
