700r4 really quick shifts under light throtte
Old Apr 17, 2012 | 10:44 PM
Dskeezy16's Avatar
Car: 1985 Firebird Trans Am
Engine: ls1
Transmission: t56
Axle/Gears: 8.8 Ford 3:73's
I got a 85 trans am with a 305tpi and a 700r4. It shifts really fast you under light throttle it goes into OD at 30-35mph and then just lugs around it won't down shift into 3 unless you floor it. Is this normal for these cars? And I already adjusted the tv cable with really no changes at all.
Old Apr 18, 2012 | 12:43 AM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Transmission: 700-R4
Re: 700r4 really quick shifts under light throtte
it's gotta be your tb cable, it's kinda tricky, make sure there is no slack in the line between the part by the tpi and the transmission, if it looks good, just push it in one more notch.
Old Apr 18, 2012 | 07:31 PM
Stevolwevol's Avatar
Car: 86 IROC Z, 92 RS
Engine: 305 4bbl, 305 TBI
I have the same thing with my 92. I was told it was a "spring" behind the valve body. I wish I could describe this better, but it would cost me over 300 dollars to fix. I just manually shift from 2nd on up. It shifts nice and firm. It's not related to the tv cable.
It's no sweat off my back though. I hardly ever just put it in gear and drive with any auto. They never shift when I want them to.
When you manually shift manually, how does it shift? Is it soft and mushy, or firm?
Old Apr 26, 2012 | 04:38 PM
Dskeezy16's Avatar
Engine: ls1
Transmission: t56
I would say its right in between its not really soft but its not hard either. I also pushed the tv cable as far in as it would go with no throttle it shifted a lot better after that but if I ever wanted to floor it it would adjust itself
Old Apr 26, 2012 | 05:16 PM
It sounds like you problem is not related to the tv cable, but you should have the transmission looked at by an out fit you can trust. Until then I recommend manually shift.
italiano67
Dec 11, 2016 09:21 AM
crazynights
Aug 21, 2015 06:53 AM
Omega
Aug 10, 2015 12:46 PM
drathaar907
Aug 6, 2015 04:20 PM
