How to wire TC lock up switch
Old Apr 18, 2012 | 03:16 PM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
First off, I did search and couldn't find an answer. I'm going to go get the car tuned/dyno'd soon. The shop says, while not necessary, having a temporary switch to lock up the TC will give more accurate readings. Two questions:
A) What gets wired where?
B) Can I just splice into the appropriate wire(s) with a 3M connector or do I have to unplug the connector to go straight to the trans so I don't eff up the ecm and/or what not?
Thanks.
Old Apr 18, 2012 | 03:23 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: How to wire TC lock up switch
https://www.thirdgen.org/torqueswitch
Old Apr 18, 2012 | 03:28 PM
watajob's Avatar
Car: 92 T/A 'vert
Sweet.
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Caspar
Jun 19, 2016 11:19 PM
Dialed_In
Aug 20, 2015 01:45 PM
355sbcTPI
Aug 19, 2015 04:38 PM
