13 secs possible w/T5 & 3:08?
Old Apr 23, 2012 | 05:15 PM
Mortorq's Avatar
Car: '88 IROC T5 Vert ‘13 Vette
Engine: 305 TBI
Axle/Gears: 3:08
Hello gents,
I am planning on replacing the nice-weather street LO3 in front of the weak sister T5 with a mild pump gas 400 sbc.
(Carb'd with a 700 mech-sec Holley, non-computer HEI, 3" Hooker cat back, Hooker 2055's, block drilled for a straight-across starter etc.)
I know the T5 is a hand grenade waiting to happen, but daughters' tuition wins out over a T56 for the time being.
So, has anyone granny-shifted their way into the 13's with a tall rear end and the requisite low rpm torque?
Old Apr 23, 2012 | 06:18 PM
T/Aperformance's Avatar
Car: 1987 Trans Am
Engine: 355 tpi
Transmission: 5 speed
Re: 13 secs possible w/T5 & 3:08?
I'm sure may be able to get a few runs in the 13s but I would not push a 5speed to much. they do not like to be slammed hard and the do not like a bunch of power.
Old Apr 29, 2012 | 02:27 AM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Maybe one time.
Old Apr 29, 2012 | 10:45 AM
yaj15's Avatar
Car: 1988 IROC-Z
Engine: L98 - full intake & exhaust boltons
Transmission: Bowtie 700r4, 2400 rpm stall
Axle/Gears: Borg-Warner 9bolt, 3.45 gears, posi
Sure it’s possible, but it won't last long in stock form. Some people are using the upgraded T-5 from G-force transmissions. The T-5 has its benefits though. Its light weight and the GM style transmissions fit in our cars with no mods.
The down side is what others have mentioned. They don't like to be speed shifted and when the power goes up, they have serious problems. Remember that GM put the T-5 only behind the LB9 and not with the L98 because of the torque capacity problems. I think the world class T-5's have a max torque rating of around 300 foot pounds. The non-world class T-5's are a little less than that. At the end of our cars run the LB9/G92/5-speed cars were rated at 230 hp and 300 foot pounds. The L98 was rated at 245 hp and 345 foot pounds.
A wise move would be to save up for a TKO 5-speed tremec style transmission or a T-56. Moving up from an L03 to an engine that will easily have a significantly more power than a stock L98 will lead to a short life for a T-5. You can do the 400 swap but you may want to baby the T-5 for a little while if you do.
Old Apr 29, 2012 | 11:14 AM
-AO-'s Avatar
Car: 3rd gen!
Engine: SBC
Transmission: yes
Axle/Gears: yes
I ran a 12.7 @ 111 in a 92 w/ 355, T5, 3.23's, and 275-60-15's. 2.0 60'. I never even shifted into 4th. Through the traps at 6000 in 3rd gear.
Fanatic1074
Oct 3, 2022 05:57 AM
rb85TA
26
Sep 14, 2015 10:29 PM
IROCZ1989
Sep 4, 2015 11:54 AM
EFR2000
Aug 18, 2015 08:54 PM
Winchester1094
Aug 18, 2015 10:23 AM
