Anyone Knows What Type Of Posi This Is
Old Apr 29, 2012 | 11:11 PM
Zach/90\irocZ's Avatar
Car: 88 Formula, 90 Iroc RIP, 92 RS Sold
Engine: 305 to 350
Axle/Gears: 10 Bolt
http://s1248.photobucket.com/albums/...achary_james3/
what posi is this i got it out of a 4th gen camaro 10 bolt will it bolt up to my 10 bolt
Old Apr 29, 2012 | 11:17 PM
82z28 wrencher's Avatar
Car: 84 Trans Am
Axle/Gears: 10 bolt 3.73 factory
Re: Anyone Knows What Type Of Posi This Is
Eaton i do beliave what ive been told https://www.thirdgen.org/forums/tran...d-rearend.html
Old Apr 30, 2012 | 12:35 AM
Engine: 305 to 350
Axle/Gears: 10 Bolt
Thanks a lot
Old Apr 30, 2012 | 06:50 AM
Looks alot like an Auburn I had that failed, out of about a 96 or 97.
Doesn't even remotely resemble the Eaton I have now.
Look for this symbol right here on it.
It's the Auburn logo.
If it has that, I'd recommend not putting it in your car.
Here's what an Eaton REALLY looks like.
http://www.summitracing.com/parts/ET...-010/?rtype=10
Old Apr 30, 2012 | 11:37 AM
Engine: 305 to 350
Axle/Gears: 10 Bolt
Ok thanks for the tip I just wait then to get a eaton
Old Apr 30, 2012 | 12:17 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
I run the 99-02 Zexel torsen diffs out of the late model fbodys... good stuff. 9 second power and still havent broke it. Only managed to chip a worm gear tooth on the outer edge but that was from doing rear end kick outs at 40mph and letting off throttle to lock up the rear, or so I believe. Never hurt it in a straight line.
Old Apr 30, 2012 | 01:05 PM
Engine: 305 to 350
Axle/Gears: 10 Bolt
That's is kind of the same as true Trac right ?
Old Apr 30, 2012 | 01:13 PM
Twin_Turbo's Avatar
that's an auburn
Old Apr 30, 2012 | 01:19 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
true trac is pretty similar to torsen diff
Old Apr 30, 2012 | 02:22 PM
Engine: 305 to 350
Axle/Gears: 10 Bolt
oh ok gotcha i was at the junk yead in seen it there and for 20 bucks and no work to get it out seem like a good idea but havent read anything good bout auburn oh well worth a try ive dont have a posi and getting tired of one wheel peels lol thought it would do till finish my other projects for the car and get a eaton
thanks for the info
when i was searching the forum i seen someone was talking about dura grip ? any of you guys heard of them ?
Old Apr 30, 2012 | 03:52 PM
chevman24's Avatar
Car: 88 and 02 Camaro's
Engine: L96 (LS) and LS-1
Transmission: auto, 6 speed
Axle/Gears: 3.42 gears for both
Get an eaton. Eatons are rebuildable at home, where as the Auburn isnt. An Auburn can be rebuilt, just not by you with ordinary tools
Old Apr 30, 2012 | 06:38 PM
Car: 84 Trans Am
uh idk i must have Aurburn as well then, but i defently dont get one wheel peel out of it lol mabye i just got a good one???
Old Apr 30, 2012 | 07:54 PM
Not really any such thing... you just got one that isn't wore out yet. But don't worry, from your description, sounds like it won't take long.
An Auburn can't be rebuilt with ANY tools, because they won't sell you the parts if the carrier is older than about 3 years. Call em and ask if you don't believe me, BEFORE you buy.
InfernalVortex
Apr 20, 2021 11:31 AM
bjpotter
Oct 4, 2015 07:48 PM
