700r4 rookie quest.
Car: 91RS
Engine: carb'd 357 vortec
Axle/Gears: 3.42 posi
700r4 rookie quest.
what does it take to put a shift kit in my tranny? what is the projected cost of doing so? and how much difficulty is involved for a DIY person?
edit: this will be behind a 350carb'd vortec with flat top pistons and a xe268h cam IDK if youneed that info but there it is
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Re: 700r4 rookie quest.
forget the cost,but when i put shift kits in my th350 and
700r4 the job was easy on both-the 700 was the more
difficult because shift kit i used for that one was more
complex and included a corvette style servo.The th350
was done under the car so i had to put up with a
constant dripping of ATF as i worked
i did the 700r4
on an engine stand,so much easier and cleaner than
doing the job under the car...
i did the 700r4on an engine stand,so much easier and cleaner than
Car: 91RS
hey what flexplate do i need to go from 89 305tbi - 700r4 to 69-78 350 carb - 700r4?
Car: '82 z28
Engine: L83 5.7
you'll need a 154 tooth meant for use with '85-earlier
2-pc.rear main seal engines.
Car: 91RS
i found this one from summit will this work and will my 305 starter work with this flexplate ( http://www.summitracing.com/parts/AA...n/?prefilter=1) or do i need this one? and what is the difference? the real ddifference? http://www.summitracing.com/parts/AA...n/?prefilter=1
Engine: 4++,350 & 305 CIs
If you put a shift kit in, the trans more often than not will fail quickly unless it is fresh or a very low mile unit.
[CA] 700R4 trans & parts
6998poncho
Sep 25, 2015 02:56 PM
