What Starter for HD SBC/T56?
Old May 7, 2012 | 01:35 AM
Copperhead's Avatar
So I've had a 383 built out of a 14093638 block (4-bolt main, 1 pc RMS out of an 87-95 HD pickup, apparently) and I'm bolting it up to an LT1-style T56. I bought an 95 LT1 Camaro mini-starter thinking I couldn't go wrong, but . . . the starter drive is about an inch away from the flywheel (153 tooth.)
Is there any factory MINI starter I can use here? Or do I need to go with a multi-position aftermarket starter? I need to stick with a light weight mini.
Old May 7, 2012 | 02:35 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: What Starter for HD SBC/T56?
If the 2 starter bolts are the same length, you don't have a 95 LT1 Camaro starter and need to get one.
Old May 7, 2012 | 09:15 AM
Copperhead's Avatar
Well, that's exactly my problem, then. Bolts are staggered, same length. Either part store guy made a mistake, or wrong starter in the box.
Thanks!
Old May 7, 2012 | 10:04 AM
LilSki's Avatar
Car: 85 Trans Am
Engine: 98 Vortec 350 LT1 Cam w/ TPI
Axle/Gears: 9 bolt 3:27
Yeah you need the 1 long/1 short bolt starter with them in line.
Old May 9, 2012 | 11:54 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
This is an LT1 starter. They're between $150-$250 new generally. I suggest you source on from a junkyard. If nothing else you can use it as a core.
Old May 10, 2012 | 01:30 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Someone screwed up
Only 2 style starters for SBC /BBC
Staggered is for 168 tooth flexplate ;153 tooth has inline holes as shown above
3rd gen money
Oct 11, 2019 09:57 PM
Gunner242
Dec 25, 2015 04:49 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
Jlanz55
Sep 29, 2015 08:55 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
