New rear axle
Car: Firebid Cab-92/1989 TTA
Engine: 383 HSR TPI
Transmission: TH700r4
Axle/Gears: 4.10
New rear axle
Hi!
Need som advice.
I am about to get a new or used upgraded rear axle/posi/gears for my firebird,it chould hold for some street/strip and aprox 500hp at the wheels.
Is there anything that bolts rigth on,do i need to swap the driveshaft aswell?
Budget aprox 2000usd.
Thanks for any replay.
Need som advice.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: New rear axle
You can upgrade your 10 bolt but eventually you will have to change it to something better so theres no sense spending money twice.
Buy a 9" housing package. You get a 9" bolt in housing and axles and you can use your current brakes on it. All you would need to do is pick up a center section locally. I'm not sure what the availability of a 9" center would be in Sweden. Don't even bother with 28 spline axles. Go right to 31 spline.
Unfortunately, shipping costs will probably eat most of your budget.
Engine: 383 HSR TPI
Axle/Gears: 4.10
Re: New rear axle
Ok
Are all 9 bolt the same length?
Should i look fot any special 9 bolt to fit my chassi?
Car: 87 IROC L98
Re: New rear axle
9", not 9 bolt. You need to buy an aftermarket Ford 9" designed for 82-92 third gens. It will have all the proper mounting attachments for the shocks, springs, torque arm etc. Trying to find and use a junkyard diff will take a bunch of refabrication of the suspension system to get it to work.
The 9" housing package with axles is somewhere around $1000. No center section, no brakes.
ambainb
Apr 25, 2016 09:21 PM
red90IROCls1
Aug 25, 2015 06:56 AM
