700R4 Full Fluid Change?
Old May 14, 2012 | 05:08 PM
FireDemonSiC's Avatar
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
I have about 5k miles on my newly rebuilt 700 and I am wanting to drain all of the no name DexIII fluid out and replace it with royal purple.
Is there any trick or technique that can be used to get ALL the fluid out of the transmission since dropping the pan will only drain 5 quarts?
I have always wondered if after dropping the pan and draining the 5 quarts can the pan be replaced and the engine briefly started with the vehicle in P to get the remaining fluid out of the converter and into the pan. Would this damage anything?
Old May 16, 2012 | 10:38 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: 700R4 Full Fluid Change?
Don't try that. To get all the fluid out, you would have to drop the VB and the separator plate, and drill a hole in the TC, the size of a rivet. Shoulda started with the Royal Purple, but it really won't help anything.
jklein337
Sep 19, 2018 06:23 PM
maroe624
Apr 16, 2017 08:29 AM
Thornburg
Aug 25, 2015 01:46 AM
kyleb24
Aug 15, 2015 08:24 AM
Leggman1
Aug 6, 2015 04:15 AM
