4th Gen axle swap questions??
Car: 86 Z28 Camaro
Engine: 5.7 Vortec
I have a 86 Camaro and my rear end is shot. So instead of spending money on fixing it I was going to do the 4th gen axel swap. I know the 93-97 are 3.5 inches wider then the stock rear end. So here's my question what is the best rear end to use? The 93-97 or 98+.
Also all I have read is that the only modifications needed was new break lines and some modifications to the E brake. Is this true?
Thanks in advanced for any info!
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: 4th Gen axle swap questions??
You'd need to consider a combination valve and speedo gears (if need be). General info below that might be of interest:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Car: 84 Trans Am
Axle/Gears: 10 bolt 3.73 factory
complete 200-300 on craigslist got mine for 75 bucks with no brakes so depends were u look
Car: 86 Z28 Camaro
Engine: 5.7 Vortec
If I grind the calipers will I be able to run a 15 inch rim? I just bought new tires and I would like to use them till I can afford the corvette rims
Car: 1986 Firebird
Engine: 5.0L V8
Thanks for the info. so should I just get a 12 bolt? I want a 3.42 12 bolt, but someone said the moser licks butt and the strange would only have 3.5 some
