???2.73 to 3.73 Swap..NEED TO CHANGE VSS???
Car: 1991 Chevrolet Camaro Z28
Engine: T.P.I. 305
Transmission: 700 R4
Axle/Gears: Richmond 3.73
I swapped the 2.73 to a 3.73 in my 91 Z28 with an automatic 700R4. I ordered the correct drive and driven gears to make the speedo correct.
My question is, do I need to change the VSS or can I use the old one?
The factory driven gear was a red, 37 tooth and I am swapping it for a purple, 43 tooth with a gray, 15 tooth drive gear.
Also, could someone tell me the difference in the two VSS sensors that are made for this car?
Thanks so much!!!!
Thanks so much!!!!
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: ???2.73 to 3.73 Swap..NEED TO CHANGE VSS???
I did not have to change the vss when I did this exact swap years ago.
Engine: T.P.I. 305
Thanks..
I went to the stealership today and they only have one VSS listed for the 91 with an automatic. Service manager told me that it should work regardless of the driven gear that is attached to it.
Do you remember which drive/driven gears you went with?
I believe the 15 tooth drive and 43 tooth driven with a 26 in tall tire will be really close.
Car: 92 RS camaro
Engine: 350 crate 300
I'm swaping from a 2.73 to a 3.23 gear. What I need to know is when figuering tire dim.should I measure with the weight of car on the tire or off. I will do the math for figuring the drivegear and driven gear just want it to be right. I RUNNING 225/60/16
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
hectre13
Dec 11, 2023 08:14 AM
