Trouble setting TV cable
Old May 17, 2012 | 03:58 PM
RWO3's Avatar
Car: '84 Camaro Sport Coupe
Engine: 355
Axle/Gears: 3.08
From what I've read, the 700R4 on my 1984 Camaro is shifting about 10mph early each gear.(2nd at 10mph, 3rd at 20mph, 4th at 35mph) So I'm trying to "reset" the TV cable but the adjusting mechanism won't ratchet/click when I try to force the throttle lever to WOT. I think I am giving the throttle lever quite a good amount of force, but the TV cable is preventing me from rotating it further and not ratcheting. I tried lubing the mechanism but still nothing.
How hard should I have to force the throttle lever to WOT until the ratcheting mechanism should click?
Also, even without the TV cable attached, the accelerator doesn't rotate the throttle lever quite all the way, as in I can rotate it maybe 1-5% further. Is that normal?
Thanks guys.
Old May 17, 2012 | 08:31 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Trouble setting TV cable
Those are okay shift points for normal driving and normal gearing. If those were your full-throttle shift points, then something would be badly wrong with a 2.73:1 axle, but about right for LO3 / LG4 with 4.56:1 gears swapped in. We don't determine good shift points by road speed anyway, we use engine RPM.
Old May 18, 2012 | 06:28 PM
RWO3's Avatar
Engine: 355
Axle/Gears: 3.08
What do you mean by 4.56:1 gears swapped in? I'm pretty sure my car has stock gears.
Unfortunately my car didn't come with a tach. Lol
Thanks for the reply.
EDIT: Yes, the shift points were at average throttle.
Old May 20, 2012 | 09:00 PM
minigunz's Avatar
Car: 1992 firebird
Engine: 3.1.... soon to be... bigger.
Transmission: 700r4, looking for t5
Axle/Gears: I havent a clue.
i had the same issue with my tv cable, i had to reset, then hold down the "D" button on the tv housing while pushing throttle to WOT to help 'pursuade' the cable through. it took a considerable amount of force for me as well. hope this helps...
Old May 20, 2012 | 09:35 PM
RWO3's Avatar
Engine: 355
Axle/Gears: 3.08
I'm not 100% sure but I think my axle ratio is 3.08. I hope my shifts are ok for 3.08 too...?
Thanks for the reply minigunz. That's kinda what I had to do as well.
Old May 21, 2012 | 05:30 AM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
If in doubt, go to
tvmadeez
site. Great info on how a TV works
Frozer!!!
Jan 19, 2024 04:55 PM
9192camaro
16
Feb 3, 2019 12:21 AM
evilstuie
Apr 14, 2016 08:52 PM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
