9 Bolt leaking...
Old May 17, 2012 | 04:12 PM
lakin454's Avatar
Car: 88 Firebird Formula
Transmission: WC T5
Axle/Gears: 9 Bolt 3.45
9 Bolt leaking...
While going through my car this spring I noticed the rear end (which is a 9 bolt from an 89 firebird) was leaking from each side. Not horrible just a little drip sitting inside the wheel. Now i've had both bearings replaced one last year drivers side and the passenger side the year before. the bearing probably arn't bad but the seals might be. The axles have to be pulled and bearings thrown away to replace the seals. Maybe the wrong bearings or seals were installed since they are side specific. Any way there is a better solution to fix the leak other then trying new bearings and seals again?
Old May 17, 2012 | 04:58 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Re: 9 Bolt leaking...
NO....
Old May 17, 2012 | 06:57 PM
lakin454's Avatar
Transmission: WC T5
Just flat out no. hmmmm
Old May 17, 2012 | 07:36 PM
DJP87Z28's Avatar
OR...Just let it leak and just add fluid.
Old May 17, 2012 | 08:38 PM
red rock's Avatar
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
I use seals from NAPA with no leaks. But yes you will have to replace the bearings and seals again, making sure the housing and axle is free of rust also. Look to make sure you don't have a groove in the axle where the seal runs, and you can also put a film of silicone on the metal edge of the seal.
Old May 17, 2012 | 08:54 PM
lakin454's Avatar
Transmission: WC T5
Thanks, I will look out for that and give the silicone a try. Hope it will work this time around.
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Numbah-1
Sep 12, 2015 08:57 PM
Jlanz55
Sep 6, 2015 07:28 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
