Possible less harsh IROC ride?
Old May 17, 2012 | 10:16 PM
Mortorq's Avatar
Car: '88 IROC T5 Vert ‘13 Vette
Engine: 305 TBI
Axle/Gears: 3:08
2 schools of thought on handling I've found.
A) GM's Herb Adams thicker sway bars and softer springs, or,
B) Dick Guldstrand's no sway bars and very stiff springs.
Any of you pros ever change out IROC springs for sport coupe springs, but keep the sway bars and IROC steering box for a slight improvement in tar-strip harshness?
'88 IROC T5 vert LO3
Old May 17, 2012 | 11:47 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Possible less harsh IROC ride?
Forget those. Leave the springs and bars alone, get new shocks and struts, then pick some tires with taller sidewalls.
Old May 18, 2012 | 01:41 AM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
You could go with RS springs, softer shocks/struts along with taller sidewall tires (which may affect your speedo reading & tranny if Automatic) but I'd start by asking a Moderator to move your Post to the Suspension / Chassis section instead of it being in the Transmissions and Drivetrain where it is now.
Old May 18, 2012 | 06:27 PM
Mortorq's Avatar
Engine: 305 TBI
Axle/Gears: 3:08
You're right. Wrong section. Also just purchased chromed 16x8 repro IROCS and added 245/50 16's. So much for my taller sidewall. oops. Mr. Moderator, could you move this post to suspension/Chassis section? Thanks.
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
88gta3508
Aug 29, 2015 08:25 PM
Linson
Aug 21, 2015 02:12 PM
mustangman65_79
Aug 11, 2015 03:17 PM
