T5 shifter goes up and down vetically
Car: 1990 Formula Firebird
Engine: 350 (5.7) TPI
Transmission: WC T5
Axle/Gears: 3.42 POSI
I did a hard acceleration and noticed from first to second my shifter was real funny, rising a couple inches and back down. Now does it while driving and under braking. Trans mount is new and looks fine. Torque arm one doesn't look so great but again, none of this happened until I punched it. Goes into every gear just fine and have not tried punching it since. What I break?
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: T5 shifter goes up and down vetically
Trans mount is the only thing preventing the trans from.coming up. It may look.good, but its broken
Car: 91 Firebird,00 c2500,75 Vette
Engine: 3.1 but 350 soon, 350, 350
Transmission: T56 soon
Axle/Gears: stock 3.42 Posi to come
I would guess trans mount also but if it is relatively new I might check to see if motor mounts are bad also causing extra stress on the tranny mount. Admittedly they are enclosed and shouldn't allow much movement but I have seen some strange things happen.
It could have been a defective mount to begin with also.
Good luck.
Good luck.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
If you consider a poly replacement, you might peruse the following info:
https://www.thirdgen.org/forums/tran...ison-pics.html
JamesC
JamesC
Transmission: WC T5
Went ahead and replaced it with a cheapie just to feel safer for the time being. Turned out the other one had ripped itself in half but you could only tell by removing it. Guess it goes to show to not always assume that a brand new trans mount can't go bad. I will be upgrading to a poly now. Thanks guys.
