how to swap a 700r4 for th350/powerglide
Old May 25, 2012 | 06:08 PM
355sleeper's Avatar
Car: 1991 camaro rs
Engine: twin turbo 406
Transmission: th400 w/brake 4400 stall
Axle/Gears: 3.42s
for those of you looking to do the swap you will need a couple parts
bmr torque arm relocation crossmember- part #TCC018R(has many points on the crossmember to raise/lower torque arm, so it also serves as an adjustable torque arm. well made piece and worth the money)
energy suspension poly torque arm bushing- part # UPI-3004 (part number brings up a umi part but it says energy suspension on it)
converter for a th350- i used a b&m 3k holeshot
shifter for th350- im using a megashifter
________________________
parts you can use-
transmission mount
driveshaft- it will need lengthened 3 inches for short tail, or you can use the stock one for a long tail.
now would be a good time to replace the u joints while its being lengthened
__________________________
its a very straight foward swap and easy to do.
THE B&M 350 INSTALL KIT DOES NOT WORK, UNLESS YOU HAVE A LONG TAIL TH350
i bought this first, the torque arm did not line up right with the short tail
i will add pics to show it all installed and i pic of the driveshaft after its lengthened.
Old May 25, 2012 | 08:02 PM
355sleeper's Avatar
Car: 1991 camaro rs
Axle/Gears: 3.42s
Re: how to swap a 700r4 for th350/powerglide
pics as promised
Attached Thumbnails how to swap a 700r4 for th350/powerglide-2012-05-24_20-13   how to swap a 700r4 for th350/powerglide-2012-05-24_20-14
Old May 25, 2012 | 08:27 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
If you use the search feature, you'll find that if you use a long tailshaft TH350, your 700R4 driveshaft is the proper length. A short tailshaft TH350 needs a driveshaft 3" longer. I have no idea why yours needs to be 5" longer.
Old May 25, 2012 | 09:18 PM
DeathStarr89's Avatar
Car: Still a 3rd Gen
Engine: 450HP 355
Transmission: TH350
Axle/Gears: 9" with 4.11's
I had the long tailshaft TH350 in mine and swapped back to a 700R4, same driveshaft.
Also the B&M kit that was there worked fine.
Old May 25, 2012 | 11:39 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
if you use the driveshaft,torque arm,tranny x-member.
from an '82 with th200 or super T-10,along with aB&M
torque arm kit,TH 350 is a near bolt in.
Old May 26, 2012 | 05:09 AM
355sleeper's Avatar
Car: 1991 camaro rs
Axle/Gears: 3.42s
I will have to measure the tailshaft. Not sure why my b&m bracket didnt line up right then. May be the same reason my driveshaft needs an extra 5 inches? Its one of the universal 350s that has a couple different bolt patterns on it.
Old May 30, 2012 | 12:41 PM
355sleeper's Avatar
Car: 1991 camaro rs
Axle/Gears: 3.42s
It is 3 inches, i had the driveshaft shoved all the way in before.
OP- fixed
camaro11j
Sep 19, 2018 08:49 AM
C409
Sep 1, 2015 03:42 PM
Eric-86sc
Aug 24, 2015 09:01 PM
spaigo
Aug 21, 2015 07:46 PM
TreDeClaw
Aug 14, 2015 06:58 PM
