T-56 delema.....
Old May 27, 2012 | 01:02 AM
brdofpry85ta's Avatar
Car: 1985 Trans Am
Engine: 6.6 at least
Transmission: T-56 (waiting)
Axle/Gears: 9" w/4.56 & spool (4 now)
T-56 delema.....
This is basically my combo...
.060 over 400 = 412 ci
Pro comp H-beam 5.7 Rods
Icon forged pistons flat top 2v....11.02 comp.
Scat steel crank
Dart Pro 1 215cc 2.05/1.60 64cc
.616in .622ex. solid roller comps cam
Crane 1.6 Roller rockers
MSD billet dist.
MSD blaster 2 coil
MSD 8.5 wires
MSD 6al box
Barry Grant Gold Claw 975cfm mech. sec.
Mallory 5-port fuel press. regulator
P.P Hurricain single plain intake
Edelbrock Aluminum water pump
True cool Aluminum radiator
K&N 3"/filter
Coated hedman long tube headers w/duel 2 1/2" pipes & 2 two chamber flowmasters dumps before the rear
9" w/spool & 4.56's
Im sure this combo is gonna make some good power...
The delema is that, I was talking to my machine shop guy and told him that I was thinking about swaping a T-56 (94 to 97)and he said they are junk and that the gearing will be garbage with the setup that I have, He said that the 1st gear would be like a granny gear from an old ford pickup.....any thoughts on this...
And doesn't the T in T-56 stand for Tremec....or aren't all stock T-56's Tremec's
Old May 27, 2012 | 01:48 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: T-56 delema.....
The 94-02 F-body MM6 ratios w/ 2.66 first / .50 sixth are exactly what you should choose for 4.56 gears. He may have had an experience with the base model 1993 Camaro (there were two) T56 ratios. Or he may be stuck on the idea that a 2.29 first gear Muncie can't be beat. Either way, ignore what he said.
The T4 and T5 were around 15 years before Tremec bought Borg Warner's light-duty transmission line. So the T matching "Tremec" was just luck. B-W intro'd the T56 for 1992 Vipers and they sold their light-duty product line to Tremec later in the 90s.
88SS6SPEED
Nov 11, 2015 07:05 AM
tonys91rs
Oct 10, 2015 03:31 PM
Hello, Michael
Aug 20, 2015 03:19 PM
cRoe4
Aug 7, 2015 08:46 PM
'91 Formula
Nov 25, 2001 04:58 PM
