Torque converter locking and unlocking.
Old May 27, 2012 | 10:41 AM
yaj15's Avatar
Car: 1988 IROC-Z
Engine: L98 - full intake & exhaust boltons
Transmission: Bowtie 700r4, 2400 rpm stall
Axle/Gears: Borg-Warner 9bolt, 3.45 gears, posi
Hey guys, I've got an issue with my torque converter. It intermittently locks up then unlocks when I am driving steady. I'm not hitting the brakes, down shifting, or taking my food all the way off the gas. I am guessing it may be a wiring issue. Does anybody have an idea about what this issue is?
Old May 31, 2012 | 04:11 PM
camaro87-alex's Avatar
Car: 1987 Chevrolet Camaro SC
Re: Torque converter locking and unlocking.
Hi.
I guess you have a L98 engine in your car with a ECM controlled converter lock up??
If so they are computer controlled to lock up at an exact speed in MPH.
That means if you are cruising slowly in 20mph or whatever the computer is commanded to, and holding it steady the computer (ECM) will engage and disengage the clutch with only small seconds between. I guess this could be frustrating some times. I know that making a new EPROM wth new data for the lock-up is a way to fix this.
Old May 31, 2012 | 05:32 PM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
You need this http://www.rickscamaros.com/camaro-t...1981-1992.html
Originally Posted by yaj15
Hey guys, I've got an issue with my torque converter. It int ermittently locks up then unlocks when I am driving steady. I'm not hitting the brakes, down shifting, or taking my food all the way off the gas. I am guessing it may be a wiring issue. Does anybody have an idea about what this issue is?
Old May 31, 2012 | 05:36 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Says it's discontinued.
Old May 31, 2012 | 05:55 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
The ECM has to see the ECM temp sender showing within a certain range to indicate the car is warmed up. It also needs a steady signal from the TPS. Hook a scanner on it and watch those values.
Old May 31, 2012 | 07:09 PM
yaj15's Avatar
Car: 1988 IROC-Z
I got the problem solved. I ordered a 700r4 trans and converter from Hughes Performance. They sent me a trans that had a wiring harness that was not compatible with the computer. The computer was not in control of locking the converter. They had a wired for a car that didn't have a computer controlling the converter lock up. I had to go through a lot of crap with them to figure that out.
I will never purchase anything from Hughes Performance again. I specifically filled out there order sheet and told them the specs for my car. I also told them that I am using the stock computer for my car so, it would control the lockup function.
I had to deal with Hughes Performance for a month trying to resolve this issue. They allowed me to send the trans and converter back and get a full rerund. I shouldn't have to pay for their issues with not following directions.
I eventually purchased another transmission from Bowtie Overdrives and that solved the issue. The lockup functions just like it is supposed to. Also this transmission shifts better.
The Hughes Performance trans would bang in to everygear even an light throttle.
83 Crossfire TA
Jan 3, 2016 01:26 PM
my86bird
Oct 23, 2015 12:20 PM
angel2794
Sep 8, 2015 06:22 PM
andy74
Sep 3, 2015 08:41 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
