speedo is off
Car: 88 iroc z28 t tops
Engine: 383tpi
Transmission: 700r4 2200 stall HD race pack
Axle/Gears: 342 detroit locker 10 bolt
speedo is off
i put a 3.42 in my 88 iroc, 700r4. What gear do i need to make it right? when i look in jegs thiers a couple of diffrent styles.
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: speedo is off
I made those 2 threads, now stickies, for exactly this reason. One tells you how to figure what you need, the other gives part numbers and colors. Why expect anyone to do your homework for you, especially without pay? What do you learn if I just give you the answer? Besides, you didn't even bother to specify what size tires are on the rear of your car. It does matter, it does make a difference.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: speedo is off
most of the gears are nla, another option would be the dakota digital sgi-5
Elephantismo
Feb 13, 2019 12:51 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
