Measurements Needed!!!
Old Jun 4, 2012 | 09:39 PM
1SICK90RS's Avatar
Car: 1991 Camaro RS
Axle/Gears: Stock
searched and searched swapping to t56, cutting the hole tomorrow and mounting my pedals and slave cylinder. i need to know how big to cut the hole for the shifter. could someone who doesn't have their console completely in please measure from where the console bolts onto the body and give me measurements front and back? Thanks!
Old Jun 6, 2012 | 08:16 AM
GTAman's Avatar
Car: 1988 Trans am GTA
Engine: corvette 350 swap
Transmission: t-5 swap
Axle/Gears: 3.27:1 borg warner 9-bolt w/ PBRs
Re: Measurements Needed!!!
i'd like to know as well! trans going in today!
Old Jun 6, 2012 | 03:39 PM
1SICK90RS's Avatar
Car: 1991 Camaro RS
Axle/Gears: Stock
looks like nobody is gunna reply, so i came up with an idea... take the shifter out, and put ur transmission all the way in the tunnel where it's gunna mount up, mark it off with a sharpie, cut it out, and pass the measurements on... good idea?
Old Jun 6, 2012 | 03:47 PM
subroc's Avatar
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
Or just measure from the front of the trans to the middle of the shifter and then measure under the car from the back of the engine to the same measurement you got off the trans and know that that is your center of where the shifter goes up.
Old Jun 6, 2012 | 03:49 PM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Thats exactly what I did. You'll still have to trim a little after that, but its a very good starting point. I'd measure mine, but my trans is out of a 03 Cobra and sits tilted in the car. So mine is probably not the same as an F-body trans.
Old Jun 6, 2012 | 04:03 PM
1SICK90RS's Avatar
Car: 1991 Camaro RS
Axle/Gears: Stock
I would, but i do not have my hands on a transmission yet. as of right now, i'm just fabbing things up, fixing to start on my dash swap soon and was really wanting to have everything mocked up before i get finished
89GTAOz
May 16, 2020 09:31 AM
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
