Trans problems shifting third
Old Jun 16, 2012 | 12:55 AM
TA-Rocks's Avatar
Car: 87 GTA, 99 VFR800
Engine: 5.7 TPI wrong heads , 781cc
Axle/Gears: 3.08, msg me if u hav 3.42 4 sale
I had an opportunity to time my car at the track yesterday and found some strange problem with my transmission. I ran five runs for test and tune and had ran two times with no problem, then on the third and fourth run the trans wouldnt shift to third. I let off the throttle and wind down then it will go into third and fourth. On the drive home it worked without troubles. This is a 87 GTA with 5.7 TPI and stall converter. I have some time slips also.
If someone familiar would look at this, that would be great. Thanks.
Old Jun 16, 2012 | 01:02 AM
TA-Rocks's Avatar
Re: Trans problems shifting third
My second run was progressing worse as the car got warmer, which may have caused a trans shift error.
1st run: 0.242 RT, 1.969 60Ft, 5.813 330Ft, 74.67 Speed, 9.087 660Ft, 93.59 vehicle speed, 14.357 ET
2nd run: 0.379 RT, 2.103 60Ft, 6.021 330Ft, 73.77 Speed, 9.334 660Ft, 90.68 Vehicle speed, 14.789 ET
Old Jun 17, 2012 | 12:32 PM
TA-Rocks's Avatar
Is there anyone familiar with my trans problem?
Old Jun 18, 2012 | 09:42 PM
TA-Rocks's Avatar
My car has some mods, but I bought it with them, so I dont know what exactly had been done with it. I will have to examine it to determine what all is done. I was told it has a different cam, pistons and heads. I do know that is was lowered and has an aftermarket panhard bar and it has poly bushings. Otherwise, I dont know for sure. How can I tell without taking it all apart? Is there any trans people familiar with this?
Old Jul 3, 2012 | 04:46 PM
TA-Rocks's Avatar
I will have to speak with a trans specialist local once I find one here. Meanwhile, is there anyone familiar with that problem?
BlackphantomZ28
Apr 24, 2016 08:14 AM
mizz0313
Aug 12, 2015 06:45 AM
dhonda200
Aug 11, 2015 11:50 PM
hokis
Aug 9, 2015 03:57 PM
