Clutch chattering 85 z28 with t56
Old Jul 12, 2012 | 02:14 PM
n8sz28's Avatar
Car: 85 camaro z28
Transmission: T56 6 speed
Axle/Gears: 3.27 borg warner 9 bolt
Just this morning clutch went out on me. Went to shift peddle went to floor. No fluid is leaking and it's making a chattering noise no matter what, if I push peddle down, in neutral. Once I stopped clutch would not disengage. I can start car in neutral but makes noise and cannot shift to first. If I put car in first and then try to start the car it wants to take off. This is a t56 application with a centerforce clutch. Could it be the throw out bearing?
Old Jul 12, 2012 | 02:40 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: Clutch chattering 85 z28 with t56
could be.
Unbolt the slave and spacer.
See if you can see the rear-most flange of the TO brg. and whether it's bent.
Old Jul 13, 2012 | 06:49 AM
n8sz28's Avatar
Car: 85 camaro z28
I will check this out for sure this weekend thanks
Old Jul 13, 2012 | 09:37 PM
n8sz28's Avatar
Car: 85 camaro z28
ended up being the clutch fork broke in half. One half was hitting the pressure plate causing the chatter. Anyone know where to grab one of these forks, I only see one on ebay.
Old Jul 13, 2012 | 09:39 PM
Last time I needed one, had to go to the GM store.... ouch
Old Jul 13, 2012 | 10:16 PM
n8sz28's Avatar
Car: 85 camaro z28
Ended up finding one on gearbox. Com, cost about 72 bucks. That was the cheapest I found too.
Old Jul 20, 2012 | 07:35 AM
n8sz28's Avatar
Car: 85 camaro z28
Does anyone know if you have to remove the transmission or at least pull it back a little to install a new clutch fork or can you keep trans connected?
Old Jul 20, 2012 | 12:13 PM
jmd's Avatar
jmd
Pull it.
Old Jul 20, 2012 | 01:36 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
I had that happen a number of years ago. Fork from GM was something like $40? Easy enough to just unbolt trans and slide it back a couple inches and slide it onto the pivot bolt. Make sure the pivot bolt is tight before reinstallation.
Old Jul 23, 2012 | 02:59 AM
jmd's Avatar
jmd
I wish they were still just $40.
FWIW, I have a fork and TO brg. in the classifieds.
Drone358
Dec 10, 2015 08:16 PM
88 TA GTA
LSX and LTX Parts
Sep 11, 2015 11:31 PM
tonys91rs
Sep 2, 2015 07:07 PM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
