9 Bolt Axle shaft play
Old Jul 31, 2012 | 03:48 PM
fast400's Avatar
Car: 89 TTA
Engine: 3.8
Transmission: 200r4
In the process of rebuilding my 9bolt (bearing, new carrier). I've got the axle shafts in and the L one has almost 1/8" of pull/push(in/out) play. How do I get rid of the excess play?
Old Apr 1, 2013 | 11:13 AM
fast400's Avatar
Car: 89 TTA
Engine: 3.8
Transmission: 200r4
Re: 9 Bolt Axle shaft play
Old Apr 1, 2013 | 05:02 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Do you have the brake backing plates and bearing retainer all installed and bolted up correctly?
With it having a pressed on bearing I wouldn't think it would have that much play but its been awhile since I worked on a 9 bolt.
Old Apr 1, 2013 | 05:48 PM
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
Axle/Gears: 9 bolt 3.27 posi
Did you replace the axle bearings already? Did you inspect the shafts under the bearing surface for wear? Did you install the seals? I read on here that you might need to remove any: paint on the outer edge of the seal to get it to seat fully.
Old Apr 3, 2013 | 12:32 PM
richardhead's Avatar
Is there a rebuild kit available for the B/W 9 bolt differential?
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
New2Chevy
Sep 28, 2015 12:35 AM
billybob6110
Sep 23, 2015 01:30 PM
greenyone
Sep 2, 2015 03:39 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
