Speedo Accuracy VS GPS Garmin
Car: 89 Formula
Axle/Gears: 9 Bolt 3.27
Guys what do you think is more accurate the GPS/Garmin or the speedometer is these cars? I see my 89 Firebird appears to be 1.5 miles an hour off slow at highway speeds. I think if changed the gear with 1 tooth less it should be closer.
if 1 tooth is equal to 1.5 MPH.
Thoughts?
Thoughts?
Car: '89 Formula WS6
Transmission: 700r4/T56
Axle/Gears: BW 3.23
Re: Speedo Accuracy VS GPS Garmin
Thoughts?
Thoughts?
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
I think you could see 1.5 mph difference just by moving your head slightly looking the gauge, unless you have digital dash. Well within accuracy tolerances for the whole system. You won't be able to get it anymore accurate than that.
A better way to check the actual accuracy of the speedo calibration is to use the odometer on a known distance. You can use gps or mile markers or a track. The longer distance you measure , the more accurate the deviation measurement. There may still be an additional discrepancy between the actual "log" (counting of revolutions) and the actual gauge display (the needle), but no way to change that besides installing a more accurate gauge.
Car: 85 IROC / 69 Firebird convertible
Engine: 5.0 / 350
Transmission: t-5 / WC t-5
Axle/Gears: 3.27 / 3.08
I think one tooth will give you more change than you want. I would be happy with the 1.5 mph off and call it close enough.
Car: `86 SS / `87 SS
The odometer may be totally accurate and the speedo off. So don't assume the gears are the issue.
The 1.5 is only "off" at one speed. So the GPS may be accurate but you may be as close as possible given the speedo gear combinations (you didn't post yours, as no one seems to do.)
There are 4 speedo gear combinations for your trans. / rear gear combo assuming stock height tires.
So there's a bit more math to do in order to determine whether you need to make that change.
Car: 85 Trans Am
Engine: 98 Vortec 350 LT1 Cam w/ TPI
Axle/Gears: 9 bolt 3:27
A tooth change is usually closer to 5 MPH change than 1.5. I would think 1.5 MPH would be more from tire wear than anything else.
Elephantismo
Feb 13, 2019 12:51 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
