I had to pull the axles for my LS1 brake swap
Old Aug 16, 2012 | 06:16 PM
blakecharles's Avatar
I had to pull the axles for my ls1 brake swap. How do I get the shims and 2 small gears back into place?? What are the torque specs on the screw holding the pin in place???
Old Aug 16, 2012 | 07:17 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
re: I had to pull the axles for my LS1 brake swap
https://www.thirdgen.org/forums/tran...axle-gear.html
29 lb-ft
did you knock the 2 spider gears out?
Old Aug 16, 2012 | 07:21 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
I think that is what he meant.
sailtexas186548
Jan 19, 2016 12:21 PM
NBrehm
Aug 25, 2015 11:49 PM
86White_T/A305
Aug 17, 2015 12:16 AM
sreZ28
Aug 14, 2015 07:48 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
