Borg Warner Rear Axle
Old Aug 23, 2012 | 09:05 AM
ig Mike's Avatar
Need help identifying rear axle. It is stamped Borg Warner and has disc brakes that are mounted opposite of one another. It also has a 3.70 or 3.73 gear ratio. I was told 87, but thinking it could be an 85 or 86? Any suggestions one what I may have?
Old Aug 23, 2012 | 09:07 AM
Twin_Turbo's Avatar
Re: Borg Warner Rear Axle
BW 9 bolt.
Old Aug 23, 2012 | 09:08 AM
87350IROC's Avatar
Car: 87' IROC
Does it have 9 bolts on the cover? If so its a BW 9 bolt. Tons of info on here. Do a search.
Old Aug 23, 2012 | 09:21 AM
Twin_Turbo's Avatar
9 bolts + rubber plug
Old Aug 23, 2012 | 11:08 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Pre 1989 BW 9-bolt rear with the Iron calipers & 10.5 rotors, 1989 had the PBR calipers & 11.655 dia rotors. Your guess should be correct for the year.
Old Aug 23, 2012 | 02:34 PM
ig Mike's Avatar
Definitely a 9-bolt with rubber plug. It also has the metric brake lines which tells me it's 84 or later.
theshackle
Sep 17, 2020 08:26 AM
AussiePr0nCar
Mar 6, 2020 04:04 PM
1986Z28OWNER
Dec 13, 2015 10:19 PM
fasteddi
Sep 2, 2015 10:29 AM
hayesaw0210
Aug 23, 2015 11:15 PM
