Problems downshifting into 2nd gear
Old Aug 28, 2012 | 11:05 AM
88knightrider's Avatar
Car: 1988 Trans Am GTA
Engine: L98, 305, 5.0L
Transmission: Stock
Hello everyone, as you can see from my profile, i have an 88 gta, i believe with the stock T5 transmittion. When i first got the car i would go from first to second gear, and second would about 60 percent of the time pop out, i brought it to my mechanic, and he did a shifter adjustment which entirely fixed that problem, now for whatever reason i have no problem going from 1st to 2nd to 3rd, but downshifting from any gear into 2nd, it physically will not allow me to do, i asked my mechanic about this he said because the T5 transmittion has really small gears close together making it impossible, and that i should look for the T56 transmittion for a swap, but i do not have that kind of money and would like a more simple solutiong, anyone know a way to fix this problem, or do i just have to live with it?
Old Aug 28, 2012 | 12:34 PM
Transmission: Stock
Re: Problems downshifting into 2nd gear
I would also like to add, that it would not downshift into second, before or after the shifter adjustment was made, i just included that in case anyone knows that the problem with second popping out has something to do with my current situation
Old Aug 29, 2012 | 01:58 PM
Transmission: Stock
TTT
Old Aug 29, 2012 | 06:30 PM
subroc's Avatar
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
I know its not the same trans but i have a TKO and downshifting to second requires a bit of finesse to make it go in smoothly. It will go in if i push it but i rev match and it slips in a bit smoother. Do you rev-match downshift or just put it in and then bring the rpms up after its in gear? Also what speed are you downshifting to 2nd at? I dont generally shift down to 2nd until im at around 25 or so.
Old Aug 29, 2012 | 09:00 PM
LilSki's Avatar
Car: 85 Trans Am
Engine: 98 Vortec 350 LT1 Cam w/ TPI
Axle/Gears: 9 bolt 3:27
The last T5 I had before the T56 swap would not downshift to 2nd or 1st. The only way to get it into 2nd at any speed was to try to go to 2nd then 1st and then it would go into 2nd. Otherwise it would not go into 2nd even if you rev matched. Getting it into first would sometime be a chore unless the car was moving slightly. Never did find out what was wrong with that trans. It is still on my garage floor.
Upshifting was always trouble free. And my current T56 is perfect in every way.
Old Aug 29, 2012 | 09:18 PM
Transmission: Stock
I am usually trying to downshift if i am at like 30 mph, and i just put it in, then increase the revs after
Old Aug 30, 2012 | 10:02 AM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
Sounds like either a synchro going bad or the shift rods aren't right. Never had a problem downshifting in my t-5s.
Do you know how to double clutch? It's rev matching in neutral before the shift into second. If that makes it better, prob indicates a synchro problem. If its still just as hard, prob shifter rod is bent or something.
junkcltr
Aug 2, 2019 11:12 PM
hectre13
Aug 26, 2015 08:17 AM
jbd1969
Aug 17, 2015 07:06 PM
dhonda200
Aug 11, 2015 11:50 PM
