th400 fit?
Old Sep 2, 2012 | 09:43 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
th400 fit?
my uncle runs a mini junkyard persay and pulled what looks like a th400 out of a camper and offered it to me, my question is, will it work? i havent seen alot of threads where a 400 was installed and am interested in doing the swap if i can get the conversion parts easy enough. im going to list some pictures of the trans, its inside a small area so the lighting really sucks but i cant tell if its a short or long shaft or even what i need.
Attached Thumbnails th400 fit?-img_4027-1-.jpg   th400 fit?-3.jpg   th400 fit?-2.jpg
Old Sep 2, 2012 | 09:44 PM
Engine: L31 350
Re: th400 fit?
and a few more.
Old Sep 3, 2012 | 02:55 AM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: th400 fit?
Why would you want to run a TH400 behind a 2.8L V6? Why would you want to lose the low 1st speed and overdrive? Just asking......
Old Sep 3, 2012 | 09:25 AM
Engine: L31 350
Re: th400 fit?
It's going behind a vortec 350
Old Sep 3, 2012 | 03:33 PM
zraffz's Avatar
Car: 1987 Camaro
Engine: LQ9
Axle/Gears: 4.10
Re: th400 fit?
Looks like a TH400 but flip it over and check out the oil pan to be certain.
I am running a TH350 (slightly more aggressive gearing than a TH400) behind a set of vortec heads.
Old Sep 3, 2012 | 07:50 PM
jbenge's Avatar
Car: 1991 Camaro Z28
Axle/Gears: Strange 12 Bolt, 3.42
Re: th400 fit?
Get a new trans crossmember from Spohn/UMI and it bolts right in. I swapped one in my 84 last winter, fits very well even with a CSI carbon fiber shield on top of it. You will have to get a new yoke and have a new driveshaft made.
Fronzizzle
Feb 9, 2017 09:31 AM
New2Chevy
Sep 28, 2015 12:35 AM
armybyrd
Carburetors
25
Sep 13, 2015 01:49 PM
BOOT77
Sep 5, 2015 03:55 PM
Formula_88AE
Sep 3, 2015 01:47 PM
