T5 clutch help
Car: 1992 firebird vert
Engine: 355 soon to be a 406
Transmission: 700r4 goin t5 then t56
Axle/Gears: 373 or 410
T5 clutch help
ok i switched from auto to a t5 when i put my 406 in my car got everything hooked up and with the car running cant put it in gear wont even grind i checked the travel on the fork and it bout 1/2 inch dont know if thats what its supposed to be or not i also am using a shatter shield instead of the factory aluminum bell housing any info on things to check would be appreciated and i have searched but havent come up with much thanks
Car: `86 SS / `87 SS
Re: T5 clutch help
Lakewood 15020?
Fork and it's spring clip in the same groove of the throwout bearing? If the clip is out of that groove, fix that first.
