4.11 rear question
Old Sep 11, 2012 | 11:08 AM
biglou87z28's Avatar
4.11 rear question
Hi everyone,
I have an 87' IROC Z-28. Swapping out the motor, and tranny, suspension, etc... doing a major overhaul. I'm looking to go with 4.11 gears for the rear posi.. Other than the gears, do i need to change the actual axle? What would I have to change exactly? It currently has the stock 3.27 Posi.
Thanks-
Lou
Old Sep 11, 2012 | 12:41 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Re: 4.11 rear question
First off does it have a 10 bolt or 9 bolt? The gears between the two are not interchangeable at all.
Since you said 3.27 I'm guessing a 9 bolt, but count the bolts on the rear end cover to confirm.
That being said 3.27 should be series 3 carrier which should accept the 4.11s. If it's 10 bolt you can get it from just about any aftermarket supplier (Summit, Jegs, etc). If it's 9 bolt you're options are more limited. www.9bolt.com has spare gear sets look at spending $275 for the gear and pinion alone though. Strange has 3.70 gears. Randy's Ring and Pinion carries 3.70 gears. Australian suppliers will carry a variety of gear ratios if you want to pay for shipping.
Gear setups are not for the novice to do in my opinion. It takes special tools to do it correctly and it takes a little bit of know how else you're new $200-$400 gears will be scrap metal in a few miles if lash isn't set correctly.
You shouldn't have to change the axles at all. The axles get reused as you're not changing the splines on the housing or anything. You'd be looking at getting an install kit (that has the seals and new bearings) then the gear itself. Expect to pay $300 to $800 for Labor to have it done (local shop or dealership).
Old Sep 11, 2012 | 01:27 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Plus changing speedo gears to compensate.
Old Sep 13, 2012 | 12:49 PM
tonys91rs's Avatar
Car: 91 Camaro RS
Engine: 305 TPI conversion.
big lou, where are you located?
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
redmaroz
Aug 16, 2015 11:40 PM
