u joint
Car: 91 formula ws6
Engine: 355 tpi OBDII
Transmission: 4l60E
Axle/Gears: 2.73 with 4th gen brakes
u joint
i purchased second hand a lingenfelter drive shaft and wanted to change the u joints. emailed the companies site last yr about it and got no response. what other way besides taking it out to identify is there or does somebody out there know off hand?
Engine: 4++,350 & 305 CIs
Re: u joint
Its junk! You better just ship it to me!! j/k I have one also but could use another one.
Y are you changing the Ujoints?
Buy a namebrand Ujoint if you need to replace them.
I'm fairly sure the rear is a cross Ujoint, not sure about the front.
You should beable to measure them in the DS..
Car: 91 formula ws6
Transmission: 4l60E
Re: u joint
i like to know what parts i can source. lol. i lost a u joint once hence the reason for said drive shaft. its getting time to install my 355 obd2 so im gonna be going thru the whole car.
sjorgens
Oct 1, 2015 07:54 PM
bubbaz28
Sep 18, 2015 02:09 PM
