Shift kit
Car: 86 chevy 28 camaro
Engine: 305 tpi
Shift kit
I have a 86 z28 with a 700 r4 it has 200,000 miles on it and it is slipping a little. Does anyone recomend putting a shift kit on it?
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Re: Shift kit
^ I agree.
Slipping means deeper problems (clutch bands).
A shift kit is meant only to be put into a mechanically sound transmission.
Depending on your build you want to do this would be a good time to look at new transmission or a good rebuild kit.
http://www.700r4l60e.com/store/home.php?cat=20
http://www.700r4l60e.com/store/home.php?cat=19
I have an old Probuilt Street/Strip (550 HP & 7,300 RPM limits). It's held up to 7000 RPM shifts fine on the street so far. Dana is a great guy. I'm sure if you call in during business hours he can direct you to the proper rebuild kit (he carries dvds too!) or freshly built one.
Re: Shift kit
As part of a rebuild.
About the stupidest thing you can do, is to try to "mod" on a wore-out major component. Unless of course you just enjoy sitting beside roads waiting on tow trucks.
Re: Shift kit
Depending on what shift the slip occurs, there are things that you can do to extend the transmission life. The oil must be in good shape. You could add the Corvette servo to improve the 2-3 shift at all throttle openings, and firm up 2nd a little. You could add the larger boost valves to help all the shifts. Both can be done with the transmission in the vehicle.
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
AmpleUnicorn88
Interior Parts Wanted
16
Nov 29, 2015 05:45 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
