which oil to use for diff??
Old Oct 9, 2012 | 05:50 PM
goliath88's Avatar
Car: 88 firebird convertible
Engine: 305 tbi v8
hey guys,
since i value your expertise, can someone advise which oil to use for the diff on a 88 firebird , 10 bolt posi rear end?? dont think its ever been done in 200+ thousand miles, so wanted to change it out. also, will that mileage be factor?? the car drives fine doesnt sound like metal rubbing or squeaky..
Old Oct 9, 2012 | 06:26 PM
Twin_Turbo's Avatar
Re: which oil to use for diff??
Hipoïd gear oil, highest visco you can get if you run it hard. Add 2 bottles of GM additive before topping off. Most are in the 80W90 range but you can get thicker or oil w/ a larger spread. I have 75W120
Old Oct 9, 2012 | 06:59 PM
big gear head's Avatar
80W90 gear oil works fine. If you have the Auburn differential then use 2 bottles of the GM limited slip oil additive. Don't use anything other than the GM additive from your GM dealer. If you have a Governor Lock then just use the gear oil by it's self. You can use a bottle of the additive if it makes you feel better, but it isn't needed.
Hotrodboba400
Dec 10, 2019 07:07 PM
tyeo098
Nov 30, 2015 06:27 PM
CatmanFS
Sep 19, 2015 09:00 AM
carattini
Sep 10, 2015 07:46 AM
rudolphschenker
Sep 4, 2015 02:41 AM
