700r4 with lt1 engine
Old Oct 21, 2012 | 08:27 PM
83day-one's Avatar
Car: 1983 Daytona
I have a lt 1 engine going in my 1983 trans am. I have the engine out of a 1993 corvette. Can I use the 700 r4 out of the firebird. It looks like the only two differences is the lockup is a 5 pin and the one from the firebird is a 4 pin. And the speedo on the corvette transmission is electronic and th firebird is mechanical. I am planning on putting in digital gauges. Also this transmission should hook up yo the engine. Any help would be great. This has been a long long project and hoping to get this motor in and started.
Old Oct 21, 2012 | 08:45 PM
LT1IROC-Z's Avatar
Car: 87 IROC
Engine: LQ9 6.0
Re: 700r4 with lt1 engine
yes,you can use the 700r4, 93 f-body's came with 700r4's,but more then likely your gonna have to pull the tail shaft on the 700 you got and replace the speedo gear and assembly with a reluctor gear and vss sensor from an lt1 car,so you'll have to do without a speedo or buy the conversion box,as far as the lockup goes,theres a kit for that as well,or you can just wire it up to a switch,hope this helps.
midge54
Dec 27, 2019 04:14 PM
camaro11j
Sep 19, 2018 08:49 AM
Reddeath210
Oct 6, 2015 08:20 AM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
