700R4 to th350 swap questions
Old Nov 15, 2012 | 08:21 PM
1991camaro_rs's Avatar
ok so im building a .040 over HCI 305 on a 150 shot, the motor i got for a steal and came with a turbo 350 trans, all in a malibu station wagon that is totally shot body, anyway the trans works great and feels awesome, question is and i have heard this but is it true the th350 will go into my camaro no problem??? like same mounts and drive shaft, also would a 3500-4000stall be ok for a n20 application?? anyway any details would be great thanks guys!!
Old Nov 15, 2012 | 09:34 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: 700R4 to th350 swap questions
Originally Posted by 1991camaro_rs
like same drive shaft,
No
T700 is longer than a common short shaft TH350
https://www.thirdgen.org/forums/post...353-post3.html
Plenty of info if you for TH350 swap
https://www.thirdgen.org/forums/sear...archid=5547104
Old Nov 15, 2012 | 10:03 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
You need the th350 with the long tail shaft, the torque arm conversion and possibly modify the trans crossmember
Old Nov 15, 2012 | 10:33 PM
thanks guys i can never find anything when i search for it but when im not i find it!!! thanks anyway guys for youre help
camaro11j
Sep 19, 2018 08:49 AM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
djmarch
Aug 11, 2015 10:22 AM
