Too much angle for t56 clutch master cyl? Pics inside...
Car: 91 Firebird 'vert, 91 Formula
Engine: 5.7, 5.0
Transmission: T56, T5
Axle/Gears: Auburn w/ 3.73's, 3.42
This angle okay? Looks similar to what Online170 had regarding angle in the T56 install sticky and a couple posted it as okay but want to be sure. Side view seems to be dead on, looking at it from front, it's definitely off some...
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Re: Too much angle for t56 clutch master cyl? Pics inside...
I would get it hooked up and see how it goes in when you push the clutch in... Mine was a bit off as well, but I haven't had any issues yet. I wish I had taken some pictures. Unfortunately I am pretty far from home. I wouldn't worry about it not being perfect, as long as it isn't too bad you should be fine. Worst case scenario it starts leaking and you have to buy a new one and adjust it a bit better... I think they are like $80 bucks.
That is honestly the reason I threw the used one in my car incase the angle was off... A lot of people suggest just going with a new one to start off.
Car: `86 SS / `87 SS
looks fine. The ball end of the rod will press the piston and not bind or drive the piston into the inner sleeve.
Engine: 5.7, 5.0
Sounds good, we'll see how it goes then. I do have a used spare in case but will keep my fingers crossed as this is a brand new setup!
There is a great deal of tolerance at that spot, with a ball-and-socket type of mating surface to accommodate it. In fact the vertical angle changes over a considerable range as the cyl is operated, and it's designed to handle that.
Looks OK to me; well within the above-mentioned range.
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Engine: 5.7, 5.0
It's a complete pre-bled gm unit and is already installed now. The backup is just the mc that came with my pedals.
rsrmoore
Aug 7, 2015 08:44 PM
