troque conveter stall
Old Nov 27, 2012 | 12:40 PM
fonzie85's Avatar
Car: 89 IROCZ
Engine: Forged 347 LS1
Transmission: Built 4L60E with 4k stall
Axle/Gears: 4th gen w/ 3.42 gears
I know this is talked about alot on here but I couldn't find the eact answer to my question. I have an 89 camaro with your basic bolt ons (headers, full exhaust, k&n filters, a chip). My trans needs rebuilt and I want to put a stall conveter in it since it will be out anyway. My question is will a 2600 stall be to much for a pretty much stock car? I do plan to someday build the motor with bigger cam, heads, intake ect. but who know when and if that will happen. any input would be much appriciated. Thanks
Old Nov 27, 2012 | 12:45 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Re: troque conveter stall
2600 RPM should be fine. I had my 2400 RPM on my 350 TPI with bolt-ons. It was great other than having issues pulling traction with street tires on the street. Ramps and things were kind of a pain too.
Remember converters come in lockup, non-lockup, and different sizes. The cheaper ones are just off the shelf so it's kinda a grab bag if they'll pull the true "flash speed" the company has advertised. More torque applied the higher the "flash speed".
Old Nov 27, 2012 | 12:46 PM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
i think it will be fine. its usually a good idea to change the converter anyway if your getting your tranny rebuilt.
Old Nov 27, 2012 | 07:19 PM
fonzie85's Avatar
Car: 89 IROCZ
Thanks guys thats kinda what I was hoping to hear. How much difference would there between a 2400 and a 2600, or between a 2200 to 2600?
What brand of converter did you have?
Old Nov 28, 2012 | 09:02 PM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Don't bother with a 2200. Stock is about 1600 RPM stall. Go for the 2600 right off the bat. Or even a 2800. These are still well within the realm of easy to live with, mild amounts of heat to deal with.
darwinprice
17
Oct 11, 2015 11:51 PM
HoosierinWA
Oct 7, 2015 10:15 AM
Jlanz55
Sep 29, 2015 08:55 AM
lanceflame44
Sep 25, 2015 12:28 PM
amcnellis
Sep 16, 2015 04:16 PM
