what 4l60e do i have
Old Dec 10, 2012 | 04:58 PM
monsterjam5000's Avatar
is there a way to find out what year 4l60e i have?
i bought it from a buddy and he has no clue what it came out of, i want to buy a stall for it but i have seen different spline count for the 4l60e transmission. i was also told the 93-97 are different from the 98+ models.
are there numbers on the trans? any help would be great.
Old Dec 10, 2012 | 05:18 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: what 4l60e do i have
Google works
The late ( LS ) 4L60E has the separate bellhousing and a 6 bolt ( vs 4 ) bolt tailshaft housing
Reg 4L60E has the bellhousing cast as part of the trans case (non removable)
Old Dec 10, 2012 | 05:23 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
is there a way to find out what year 4l60e i have? are there numbers on the trans?
If the factory sticker is still on the trans you can look that info up on line
http://ls1tech.com/forums/automatic-...-came-out.html
Old Dec 10, 2012 | 10:38 PM
i have Reg 4L60E how many spline converter does it use
Old Dec 11, 2012 | 11:37 AM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
is it a v6 or a v8? v6 uses 27 spline. v8 uses 30 spline.....or you could count the splines and know for 100% sure....
Old Dec 14, 2012 | 04:05 AM
Pro Built Automatics's Avatar
The LS Series has a bolt hole at the top of the bell housing. The LT Series does not. Both have 30 splines. The LS has the torque converter clutch seal behind the splines on the input shaft. The LT has the torque converter clutch seal it in front of the splines just like the 700R4. The bolt on bell housing started in 1996 in some vehicles. By 1998 all 4L60E's had the bolt on bell housing.
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
Nervous2
Oct 8, 2015 10:53 PM
LSXcamaro
LSX and LTX Parts
Sep 17, 2015 11:17 PM
IROCZ1989
Sep 4, 2015 11:54 AM
f-bodyz28
Sep 2, 2015 05:03 PM
