TCC Lock-up in Reverse?
Car: '91 Z28 L98 G92
Engine: Modded L98
Transmission: Modded 700R4
Axle/Gears: Modded 10-Bolt
I know it wouldn't be 'normal,' but is there any condition / defect that could make the trans try to lock the TC in Reverse?
The problem I'm having is stalling when shifting from Drive to Reverse, or Park to Reverse, AFTER the car is warmed up. Does Reverse just fine when backing out of the driveway first thing in the morning, but then drive it 5 - 50 miles and it will lug really badly ( usually stall) when shifted into Reverse. I put it R once and kept the engine running w/ left foot on brake and right foot tickling the gas...made a kind of squealling sound (wasn't the tires). Could I have been overpowering the TCC between engine torque and brakes locked?
Bill
Bill
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: TCC Lock-up in Reverse?
Would have to look at the hydraulic diagrams, but I don't think it can.
Engine: Modded L98
Thanks for the reply Apeiron; any thoughts on why the car otherwise drives fine, but shifting to Reverse kills the engine, even when trying to keep the revs up with the gas pedal?
Maybe the car is just nervous because it knows I'm taking it in for an Emissions Test today! LOL /JK / etc. etc.
Thanks again.
Thanks again.
Engine: Modded L98
Could I troubleshoot the issue by disconnecting the plug on the L/H side of the trans? Or does that electrical connection control more than TCC lock-up?
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
You could, it also tells the computer when it is in 4th gear.
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Disconnecting the brake switch s plug has same effect as disconnecting the plug at the trans ( and prob cleaner to do)
UltRoadWarrior9
Apr 28, 2020 10:39 PM
ramicio
Sep 28, 2015 01:18 PM
