Automatic Transmission disconnected electrical connector / what is it?
Car: 1989 RS Convertible
Engine: 305 TBI
Transmission: Automatic
I am changing the filter in my automatic transmission. When lowering the pan I notice a two prong electrical connection next to the shift linkage on the driver side of the transmission that is not plugged into anything. Does anybody know what this would be and if it needs to be plugged in. The transmission runs fine.
Any helped would be most appreciated.
Buck
Buck
Car: 1986 Corvette
Engine: 5.7 liter
Axle/Gears: 3.07
Re: Automatic Transmission disconnected electrical connector / what is it?
Sounds like it might be for the TCC (Torque Converter Clutch) lockup solenoid.
Mine is hard wired into the wiring harness, so no 2-pin connector.
Car: `86 SS / `87 SS
TCC in an '89 isn't 2-prong and that year wouldn't have a VSS connector originally.
Post pictures.
Post pictures.
Car: 1986 Corvette
Engine: 5.7 liter
Axle/Gears: 3.07
I was under the impression he was talking about a connector inside the trans. I guess that was my error.
Good point. Back to pictures.
Dialed_In
Aug 20, 2015 01:45 PM
95, auto, camaro, connector, connectors, drivers, electric, electrical, electricalconnector, gen, inside, instal, prong, side, top, trans, transmission
