Leak from VSS???
Old Dec 30, 2012 | 09:50 AM
86FyrBrd's Avatar
Car: 1992 Camaro Z28 Convertible Z03
Engine: 383 SuperRam
Leak from VSS???
In my years around thirdgens and the past 8 years I have spent around Jeeps I have learned a lot about vehicles. Building engine, rears, interiors, tons... to much. But I dont know Jack about transmissions.
This vert I got is in great shape but has a few minor issues. One of which is a tranny leak at the rear of the tranny. It doesnt look to be where the tail housing bolts on. It actually looks to be at the VSS sensor? Is there fluid in that part? Can the VSS leak or does it need to be coming from somewhere else? I apparently need a VSS because my speedo/odo isnt working. Its plugged in but not working. Between that not working and the leak Im guessing the VSS is shot. Can anyone school me on this a little bit please.
Old Dec 30, 2012 | 10:12 AM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: Leak from VSS???
Short answer is yes, the VSS/speedo cable adapter can leak. It's got an o-ring on the outside.
Take it out (as in completely remove it from the car, disconnecting the wire harness), and hook a DMM to the terminals in the plug. Take the gear off of the shaft, and spin it with a drill. You should get an AC voltage reading out of it. If you do, it's good. Replace the o-ring on it and put it back in. Then go to the Electronics section and search for info on code 24 (VSS malfunction).
Old Dec 30, 2012 | 10:37 AM
86FyrBrd's Avatar
I just pulled it and I think I found the problem at least for the leak. It was barely torqued in there. I don't know the torque value it should be at but I know it came out with the slightest one handed tug with a 3/8 ratchet. Backed it off a few revolutions and it dropped right out. Seems it was never put in right.... I have read a few threads on here where they were in so tight people had to remove the tail housing and tap these out from the inside.
Old Dec 30, 2012 | 10:48 AM
Downshift's Avatar
Car: 91 Camaro Z28
Engine: 5.0L LB9 305 TPI
Transmission: 5 spd
Axle/Gears: 3.42 Rear End
Yes they will leak. I replaced mine about 2 years ago. It was just the o-ring that was scuffed for some reason. I just went and replaced the whole thing as I found one for a few bucks. But they also leak from the back (round metal) part.
oh, just noticed you figured it out. Good news.
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Reid Fleming
Oct 10, 2015 09:56 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
aaron7
Sep 30, 2015 09:15 AM
