Tranny Help
Old Dec 31, 2012 | 08:34 AM
Tallonejosh's Avatar
Car: 1991 CAMARO
Transmission: automatic
Tranny Help
I have a 91 camaro v8 W/ 305tbi and an automatic transmission, but I was having transmission problems and was in need of replacing it. Soo i was able to find a used transmission locally and picked up a new torque convertor. Swapped it out without any problems, filled it up with transmission fluid and went through the gears to get any air out of the lines, but it doesn't move. It doesn't do anything when i switch gears, it doesn't even try to move, what could be the problem?
Old Dec 31, 2012 | 12:07 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: Tranny Help
you can check pressure to see if the pump is working.
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
bjpotter
Oct 4, 2015 07:48 PM
Stryker412
Sep 7, 2015 09:11 AM
apie2546
Sep 5, 2015 07:40 PM
IROCZ1989
Sep 4, 2015 11:54 AM
