VSS Speedo Gear Confusion
Car: 92 Camaro RS
Axle/Gears: 3.73 Truetrac
So I have done the math, 15/44 is what i need for 3.73 with 4L60E and 245/50/16 tires.
Best I can see for my VSS i need 8642620 (15 tooth drive) and 25513051 (44 tooth driven).
I keep seeing these numbers for a speedo sleeve, what is this, no pictures found searching google or thirdgen. Web sites just show it discontinued much like most the speedo gears. Do I require this? Looks like it could be part# 25007339? or 25007308 or 104589... what is this and what determines which part?
Where is the best place to buy the gears and sleeve if needed? Like I said most places seem to be out of stock on at least one of them.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: VSS Speedo Gear Confusion
most of these are discontinued the best choice is a dakota digital sgi-5
Car: 92 Camaro RS
I already acquired the gears, just unsure of this sleeve. What is it, when do you need it, what determines what one you need?
Posted from Thirdgen.org App for Android
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
