Random Shifting Woes
Old Jan 6, 2013 | 09:04 PM
armybyrd's Avatar
Car: '02 T/A
Transmission: 4l60e
Ive got an '85 Z28 with the 700r4. This morning I drove about 20 miles with no issues, I then parked the car for a few hours then drive across the street and shut if off. After only a few mins I get back in and the car wouldnt shift out of first until about 3-3500rpm and it was a pretty hard jerk when it finally did. Several hours later I get back in and drive another 20 miles back to post with the car not shifting until 3-3500 rpm. I shut it off and just a few mins later get back in and the car was back to normal shifting at the normal times.
I plan on changing my fluid/filter asap. Any idea as to what could be the problem?
Old Jan 9, 2013 | 07:40 PM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Re: Random Shifting Woes
well i have recently had this problem with my 86 camaro and it was a combination of a broken governor gear and a stuck/worn valve in the valve body. the repairs cost $ 200. and the shop didnt even have to remove the trans to repair it. now all is well .SO this is where id start if i was you. hope this helps you out
Fanatic1074
Oct 3, 2022 05:57 AM
RS Reaper
Oct 17, 2018 07:52 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
ndndndnd
Sep 28, 2015 08:00 AM
