G-force t5?
Old Jan 28, 2013 | 05:35 PM
bison999's Avatar
Car: 1984 Firebird S/E
Engine: 2.8 carbed
Transmission: Warner T5 5 Speed
G-force t5?
So i was looking around for upgrades for a swap im planning in the future, and i read about g-force transmissions and saw the can upgrade gears to the bw t5. anyone have any experience with this company or ever tried the gear swap? any info would be just great.
Old Jan 28, 2013 | 06:01 PM
soarestransam's Avatar
Car: 1988 Gta trans am
Engine: LR4 4.8
Transmission: 98-02 t56 6 speed
Axle/Gears: Bw 9 bolt (3.70’s) pbr rotors
Re: G-force t5?
For how much ur gonna try to rebuild the t5 better off going t56
Old Jan 28, 2013 | 06:25 PM
MY-92-RS's Avatar
Car: 92 CAMARO RALLY SPORT
Engine: 383 sbc w/250 shot of nitrous
Transmission: AMERICAN POWERTRAIN- EXTREME TKX
Axle/Gears: STRANGE ENG. 12 BOLT 3:90 SPOOL
Re: G-force t5?
I had mine done several years ago ...Can it be done yes for a price ..Mine was built by Hanlon motor sports with all G-force internals including bronz shifter forks set up for SCCA road racing it can take 7200 rpm power shifts ( No Lifting the Gas here !!) from a NOS sniffing small block 358 all day long If I had to do it today considering how easy it is to to the the Swap even I would Do a T-56 money wise it is the best way to go ...
Old Jan 28, 2013 | 07:06 PM
subroc's Avatar
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
Re: G-force t5?
Agreed. There is a reason why so many go T56. Because you really cant beat the strength and price when all is said and done. T5 with gforce everthing will run you over 2k. For that price your in TKO territory which i have. Even coming from someone who has a tko..id say go the t56. My tko is a headache.
Old Feb 1, 2013 | 02:23 AM
DBLTKE's Avatar
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
Re: G-force t5?
It's not really the gears that are weak, its the T-5 case.
Old Feb 2, 2013 | 05:22 PM
MY-92-RS's Avatar
Re: G-force t5?
Agreed G-Force has solved this issue by changing the helical cut on the gears less load on the case however .. A lot better setup with a T-56 you can run 4:10 or even 4:56 gears out back and drive it on the highway all day long 6 gears or or 5 you do the math
Old Feb 2, 2013 | 05:28 PM
Re: G-force t5?
Yup; the G-force thing, or one or 2 similar other, is pretty much all there is, for people who HAVE TO run a T-5 (rules of a sanctioning body for example); but for anybody without such a constraint, it's AHELLUVALOT of money in exchange for AHELLUVALOT LESS THAN what you get with a T-56.
West Coast GTA Man
Feb 9, 2009 07:45 PM
rx7speed
Jan 31, 2002 01:58 PM
BuckeyeROC
Aftermarket Product Review
Dec 24, 2001 10:32 AM
Darrell
Aftermarket Vendor Review
Jun 24, 2001 11:56 AM
Ih8myZ28
Mar 4, 2001 11:52 PM
