Heating the ring gear to fit on posi.
Old Jan 31, 2013 | 08:54 PM
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
Axle/Gears: 9 bolt 3.27 posi
Well, it's 29 degrees tonight and my posi is outside while my ring gear is in the house.
I have read about heating the ring gear in the oven and putting the posi in the freezer to get a slip on fit without using the bolts to draw it down.
My question is how hot should the oven be? Are there any tips or tricks I should know about when doing this?
I have already cleaned the ring gear with brake cleaner.
Old Jan 31, 2013 | 09:52 PM
Re: Heating the ring gear to fit on posi.
Just, warm. Doesn't have to be "hot".
Old Feb 1, 2013 | 06:33 AM
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
Thanks Sofa, that's what I was wondering. 7 degrees without wind chill this morning, so that posi should be well chilled!
Old Feb 1, 2013 | 06:57 AM
big gear head's Avatar
I would't go over about 200 degrees. If you get it too hot you can mess up the heat treat and make the gear soft.
Old Feb 1, 2013 | 10:32 AM
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
Gotcha BGH.
Old Feb 1, 2013 | 10:22 PM
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
Hour and a half at 185 degrees and she went on like butter. Thanks guys!
Old Feb 2, 2013 | 09:38 PM
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
86IROC112
Aug 21, 2015 07:20 PM
kyle5647
Aug 15, 2015 11:56 PM
